MAGNETIC SHEET SAMPLE KIT
    TDK(东电化)
    RF ABSORBING SHEET 140X95MM KIT
MAGNETIC SHEET SAMPLE KIT 数据手册
Nov. 2018 TDK Corporation P/N: MAGNETIC SHEET SAMPLE KIT All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies ■ Sample list "Magnetic Sheet Sample Kit" includes the following: Magnetic Material Thickness (mm) Series Product Name Sample Size (mm) Qty 0.025 IFL10M-025NB 140X95 1 0.050 IFL10M-050NB 140X95 1 3 0.100 IFL10M-100NB 140X95 1 4 0.200 IFL10M-200ND 140X95 1 5 0.050 IFL12-050NB 140X95 1 0.100 IFL12-100NB 140X95 1 0.200 IFL12-200ND 140X95 1 IFL16-030NB 140X95 1 IFL16-030EB 140X95 1 IFL16-030GB 140X95 1 No. Series 1 2 IFL10M 6 IFL12 7 8 0.030 9 10 IFL16 11 0.050 IFL16-050NB 140X95 1 12 0.100 IFL16-100NB 140X95 1 0.025 IFM10M-025BB 140X95 1 0.050 IFF08-050ND 140X95 1 15 0.100 IFF08-100ND 140X95 1 16 0.050 IFL04-050NB 140X95 1 0.100 IFL04-100NB 140X95 1 0.200 IFL04-200ND 140X95 1 13 IFM10M 14 IFF08 17 18 IFL04 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Nov. 2018 Ver.2.0 TDK Corporation Noise suppression sheet - Flexield - Series name IFL(normal) IFM(with copper) IFF(Heat-resistant) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies ■ Material characteristic(Relative permeability) Material name IFL10M IFL12 IFL16 IFF08 IFM10M Recommended specification frequency range 10MHz 5MHz 0.5MHz 10MHz 0.5MHz to 3GHz to 3GHz to 1GHz to 3GHz to 10GHz Relative permeability (at 1MHz) Surface resistivity (Ω/sq.)min Thermal conductivity (W/m・K) 120 180 220 100 120 1M 10k 10k 1M 1M 1.5 1.5 1.5 1.5 1.5 Operating temperature range (℃) -40 to +85 -40 to +85 -40 to +85 -40 to +125 -40 to +85 Frequency vs. Permeability 250 Permeability 200 IFL10M u' 150 IFL10M/IFM10M u" IFL12 u' IFL12 u" 100 IFL16 u' IFL16 u" 50 0 1 10 100 Frequency [MHz] 1000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies ■ Material characteristic(Transmission attenuation) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies ■ Material characteristic(Transmission attenuation) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2017 Ver.1.0 TDK Corporation Magnetic Sheets for NFC & RFID - Flexield - Series name IFL04 series All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies ■ Material characteristic(Relative permeability) Material name Relative permeability (at 13.56MHz) typ. IFL04 u'/u"=45/1.3 Surface resistivity (Ω/sq.)min 10k Thermal conductivity (W/m・K) Operating temperature range (℃) 1.5 -40 to +85 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS When mounting on live electrical parts directly, there is a fear that an insulation accident is caused, so please consider on the design in case of use. There is a fear that sullenness of double sided adhesive tape occurs, so please refrain from the use to a part where you wind repeatedly by which it's for the hinge part. The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. When the damage occurs by having been used the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please understand that the responsibility cannot be taken. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using these products in general purposes and standard use, it is recommended that protection circuits are used, devices are secured, and backup circuits are kept for increased safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
MAGNETIC SHEET SAMPLE KIT 价格&库存
很抱歉,暂时无法提供与“MAGNETIC SHEET SAMPLE KIT”相匹配的价格&库存,您可以联系我们找货
  • 1+1961.902631+254.61915
